Community Member
DSL client cannot browse
VPN 3005 (v3.7) behind a Pix 515 (DMZ).
Dial-up access from a Win98 laptop connects, can browse vpn network shares, ping, telnet, map, etc.
DSL access from client 3.6 on a Win XP box can connect and ping vpn resources, but cannot telnet, or browse to any of the vpn resources.
The laptop dials direct, while the XP box is part of a home LAN using Ameritech DSL. Neither network (home or office) is running WINS (all 2000 or XP machines (with exception to the laptop)).
Is this something NAT-T can fix (e.g. the XP machine is sitting behind a NAT router), or is something else going on?
1 REPLY
Community Member
Re: DSL client cannot browse
Here are some of the things that you could try and see if they work for you.
1) Enable IPSec over NAT-T
2) Allow IPSEC over UDP
3) The Cisco VPN Client is not compatible with any DSL service that requires the use of a PPTP client to access the DSL service (Bug CSCdu05319). Make sure that is not the case.
97
