07-31-2003 04:09 AM - edited 02-21-2020 12:42 PM
Host router at fixed public IP address; 1 remote LAN at a dynamically assigned IP; support for VPN client from several remote locations.
Last time we tried this, it was quite problematic and ended up with fixed IP at remote.
This time, not fixed IP not likely; any updates for a suggested approach in IOS at host?
07-31-2003 10:11 PM
You can do this with IPSec profiles in 12.2(15)T. I'll email you a sample config I've made up that hasn't been posted to CCO as yet.
08-12-2003 02:02 AM
I also have a problem on ipsec. I also have a host with fixed public IP and two or more remote host. There is worked fine between remote and host. But I got the problem on remote to remote using host as gateway. It did not work. Do you have any comments? Please advice.
R2-------------R1-------------R3
R1=Host, R2,R3=Remote
R2 cannot ping with R3. R1 can ping R2 and R3.
Godwin
08-26-2003 01:12 PM
I have the same problem. Can you please mail me config from hub and spoke router ?
My email is kristine.meganck@realsoftware.be
08-28-2003 06:50 AM
08-31-2003 08:19 PM
Can you e-mail to me as well. godlam@netvigator.com
09-01-2003 02:39 AM
Did somebody received the config ? Is it possible to post it. I have some troubles with it and want it ASAP solved ...
Please help
Thx
