Dynamic Translation of Fierwall module on 6509
huiming.lin
A Catalyst 6509 with two SUP2 and two Firewall Module,Two Firewall Module is failover. Dynamic Translation¡¢Static Translation and Static route were configed on Firewall.The switch was rebooted because of the power was down abruptly.After switch's reboot was finished all connection status were shown right.The Static Translation and Static route were right also,but the dynamic translationg is not work.Show Xlat can list the Pat entries,but PAT was not work in fact.We rebooted the firewall module with command,but no effect?The firewall was recovered after we clear all configuration on firewall and reconfiged it.
What is the reason of this instance,what should we do next time.
jsivulka
Level 5
Level 5
Did you try the clear xlate command. That should clear all the existing translations.
I tried clear xlate severay time,but I feel this command invalid.After execute this command all the translated entry were still exist.
