Community Member
Easiest way to connect IOS router to PIX with IPSec
I need to connect several dozen IOS routers to my PIX using IPSec. I was thinking about doing it manually until I saw several references to Cisco Easy VPN. This looks like it could be an attractive option to editing a bunch of config files. However, I can't seem to find any technical documents on the setup of EzVPN. All I seem to find is sales literature. Is EzVPN the way to go here? If so, can somebody point me to some good tech docs on this technology?
Diego
Re: Easiest way to connect IOS router to PIX with IPSec
Here's the EzVPN Phase 2 documentation. Note you'll need to be running 12.2(8)YJ on the routers to use this feature. http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122limit/122y/122yj/ftezvp2.htm
Here's a sample config for configuring it on the router (http://www.cisco.com/warp/public/471/vpn_ios_ezvpn.html), although this is a Phase 1 EzVPN setup and it's to a VPN3000 concentrator. Just ignore all the VPN3000 stuff and look at the router config, and Phase 2 introduced a "connect auto" command that'll automatically re-connect the tunnel after a timeout, rather than you have to wait for traffic from the remote site, which is good for management purposes.
The PIX side of the configuration is just a standard VPN client configuration, since the EzVPN client looks like a standard client connection: http://www.cisco.com/warp/public/110/pix3000.html
Note that the group name and password in the PIX config and the group name and password used in IOS obviously have to match.
Community Member
Thanks for the great links!
Diego
123
