10-21-2003 02:05 AM - edited 03-09-2019 05:13 AM
I'm struggling here, i'm not a firewall expert but need to roll out a PIX 501 firewall very quickly.
I've always used Watchguard firewalls in the past where its really easy to just use the graphical interface and tell it to 'forward all http traffic to 192.168.1.2' or 'forward all smtp traffic to 192.168.1.5' etc.
How do i do this with the Cisco PIX 501 firewall? i am using the PIX Device Manager program and can see how to add rules to allow http,ftp,smtp etc through but cannot see where to tell it to forward certain packets to a certain service host on the external network.
I've seen solutions that use command line instructions but i am unable to use these as i am not familiar with Cisco commands so i really need to do it through PIX Device Manager's GUI.
Where do i start, i cant find any documentation to point me in the right direction. This model also includes the line 'easily forward traffic to an internal web server' in its advertising literature!?!
Any help much appreciated.
10-21-2003 04:10 AM
Further to this, i've tried to configure it by using the command line, my config is looking like this:
Building configuration...
: Saved
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname pixfirewall
domain-name ciscopix.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list 101 permit tcp any host 80.177.XXX.XXX eq www
access-list 101 permit tcp any host 80.177.XXX.XXX eq 3403
access-list 101 permit tcp any host 80.177.XXX.XXX eq smtp
access-list 101 permit tcp any host 80.177.XXX.XXX eq ftp
access-list 101 permit tcp any host 80.177.XXX.XXX eq https
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 80.177.XXX.XXX 255.255.255.248
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.2 255.255.255.255 inside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) 80.177.XXX.XXX 192.168.1.2 netmask 255.255.255.255 0 0
access-group 101 in interface outside
route outside 0.0.0.0 0.0.0.0 80.177.32.97 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:5263591bb4712968f159e2b88bd7d0d8
: end
[OK]
I just want it to forward all www,smtp, ftp and port 3403 traffic to internal server 192.168.1.2 can anyone see anything obviously wrong with the above config.
10-21-2003 04:10 AM
: Saved
PIX Version 6.3(1)
enable password xxxx
passwd xxxxx
names
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
terminal width 80
Cryptochecksum:xxxxx
: end
[OK]
