05-02-2006 11:30 PM - edited 03-09-2019 02:47 PM
i am not a good Pix user, i need to create a new Network on a same physical interface, according to me i need to move my physical configuration to a virtual and let the physical with no ip address, i'm looking for the easisest way to do it without loosing ACL's, nameif and ip scheme.
05-02-2006 11:56 PM
You can either copy your existing config after doing a show run or you can use a tftp server and save your config that way. TFTP is my personal preference that way you get all your isakmp keys saved.
write net x.x.x.x:/pix.cfg
replace the x's with your tftp server and that will get it saved. Now you'll have to start the process of reconfiguring your pix. Being that I have not done a transparent configuration and may just have to convert my test pix to one I can't really help you from there.
Patrick
05-03-2006 03:47 AM
so you want me to send to you the configuration file i have just extracted, that's it ??
