Easy VPN and IPSec with PSK,Wild-card and Mode-Config
I tried to configure a 1720 Router with IOS 12.2(8)T
to act as an Easy VPN Server for Cisco VPN Clients and as an IPSec-GW (IPSec over L2TP) for MS VPN Clients (2000 and XP)at the same time.
After I configure the IKE PSK wild-card I cannot connect with Cisco Easy VPN Client. Has anybody a idea?
Here is my configuration:
1700#sh run
Building configuration...
Current configuration : 2670 bytes
version 12.2
hostname 1700
aaa new-model
aaa authentication login remoteuser local
aaa authentication ppp default local
aaa authentication ppp vpdn local
aaa authorization network author local
aaa session-id common
enable password isabel1
username xxxx password xxxx
memory-size iomem 15
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
vpdn enable
vpdn-group remote
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
local name lns
lcp renegotiation on-mismatch
no l2tp tunnel authentication
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
lifetime 3600
crypto isakmp policy 10
hash md5
crypto isakmp key isabel1 address 217.1.2.3 no-xauth
crypto isakmp key isabel2 address 0.0.0.0 0.0.0.0 no-xauth
crypto isakmp client configuration address-pool local cisco
crypto isakmp client configuration group remoteuser
key isabel1
dns 10.10.10.10
wins 10.10.10.11
domain test-lab.com
pool cisco
crypto ipsec transform-set siteset esp-3des esp-md5-hmac
crypto ipsec transform-set remoteset esp-3des esp-sha-hmac
mode transport
crypto dynamic-map remote 1
set transform-set remoteset
set pfs group2
match address 101
crypto dynamic-map easy 1
set transform-set siteset
crypto map sitemap isakmp authorization list author
crypto map sitemap client configuration address respond
crypto map sitemap 1 ipsec-isakmp
set peer 217.1.2.3
match address 100
crypto map sitemap 2 ipsec-isakmp dynamic remote
crypto map sitemap 3 ipsec-isakmp dynamic easy
interface Loopback1
ip address 10.10.10.1 255.255.255.0
interface FastEthernet0
ip address x.x.x.x 255.255.255.0
speed auto
crypto map sitemap
interface Virtual-Template1
ip unnumbered FastEthernet0
peer default ip address pool ipremote
ppp authentication ms-chap callin
ip local pool ipremote 10.10.10.2 10.10.10.3
ip local pool cisco 11.11.11.1
ip classless
ip route 0.0.0.0 0.0.0.0 217.1.1.2
ip route x.x.x.x 255.255.255.0 217.1.1.2
no ip http server
ip pim bidir-enable
access-list 100 permit ip 10.10.10.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 100 permit ip 11.11.11.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 101 permit ip host 217.1.1.1 any
snmp-server community testro RO
snmp-server community testrw RW
line con 0
line aux 0
line vty 0 4
password xxxx
line vty 5 15
password xxxxx
end
1700#
Thanks for help
1 REPLY
Silver
Re: Easy VPN and IPSec with PSK,Wild-card and Mode-Config
Here is the link to a document on Configuring Cisco IOS Easy VPN. Hope this helps.
http://www.cisco.com/en/US/netsol/ns340/ns394/ns171/ns27/networking_solutions_white_paper09186a0080189133.shtml
984
