Easy VPN - - - any help???
I've configured the router as Easy VPN Server and can conect to router from other internet host using Cisco VPN Client.I can ping from the VPN Client to the router or any host.However I can' file share from the networks.Since I'm doing this as practice I'm not sure what can be done using VPN access and How?
thanks for your advise.
Sourav
1 REPLY
Re: Easy VPN - - - any help???
On the VPN client PC under the network connection properties, make sure "Netbios over TCP" is checked. Windows file sharing is all done via NetBios so you need to make sure that is able to go over the VPN tunnel. Additionally, make sure on the Easy VPN Server router that in the VPN config you're sending down an intenal WINS server address to the VPN client.
106
