Easy VPN Cable router (831) to 3005 Concentrator - no data passing thru
tac very unresponsive on this issue, please help if you can.
tunnel establishes just fine, however not able to pass any data from 831 to 3005. am seeing that packets are passing 3005 to 831, just not returning. do i need routes on the 831, have tried many different default routes. do i need access lists with easy vpn, thought they are established automatically. possibly a nat issue?
here is my 831 config, please tell me what may be needed:
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname home
enable secret 5 $
ip subnet-zero
ip name-server 10.176.1.20
ip name-server 10.176.1.19
ip dhcp excluded-address 10.10.10.1
ip dhcp pool client
import all
network 10.10.10.0 255.255.255.0
next-server 10.176.2.51 10.176.2.52
default-router 10.10.10.1
lease infinite
ip urlfilter alert
ip audit notify log
ip audit po max-events 100
crypto ipsec client ezvpn VPN
connect auto
group vpngroup key MyPassword
local-address Ethernet0
mode client
peer 1.2.3.4
partition flash 2 6 2
interface Ethernet0
description LAN interface
ip address 10.10.10.1 255.255.255.0
no cdp enable
crypto ipsec client ezvpn VPN inside
hold-queue 32 in
hold-queue 100 out
interface Ethernet1
description WAN link
ip address dhcp client-id Ethernet1
no cdp enable
ip nat inside source list 102 interface Ethernet1 overload
ip classless
ip http server
no ip http secure-server
ip access-list extended wanin
permit ip 1.2.3.0 0.0.0.255 any
access-list 23 permit 10.10.10.0 0.0.0.255
access-list 23 permit 1.2.3.0 0.0.0.255
access-list 100 permit ip any any
access-list 102 permit ip 10.10.10.0 0.0.0.255 any
access-list 169 permit udp any host 1.2.3.4
access-list 169 permit udp host 1.2.3.4 any
no cdp run
line con 0
exec-timeout 120 0
password 7
login
no modem enable
stopbits 1
line aux 0
password 7
login
stopbits 1
line vty 0 4
access-class 23 in
exec-timeout 120 0
password 7 1111
login
length 0
scheduler max-task-time 5000
end
  • Other Security Subjects
Re: Easy VPN Cable router (831) to 3005 Concentrator - no data p
i have configured sites for my organization using ezvpn on an 8xx to 3005
you say that you are recieving traffic from the conentrator but cannot pass traffic to it
here is a list of things to check
-Make sure that your ezvpn group "vpngroup" is NOT setup for IPSec over UDP on the Concentrator
-Check on your Concentrator for discarded IPSec packets ->Monitoring | MIB Stats | IPSec (i think this is it, if not you'll find it around there)
-do you see encryptions or decryptions failing on the IOS router
show crypto engine client connections active
First and foremost......on the Concentrator, make sure that the Group Profile does NOT use IPSec over UDP. Ezvpn does not use it and there will be a mismatch. Your tunnels will establish, but data traffic will not flow. Just use straight IPSec. also make sure there are no conflicting filters in place on the Concentrator.
and
does your 3005 have a default route to the Internet?
try using this default route on your ezvpn IOS router
ip route 0.0.0.0 0.0.0.0 ethernet1
also remove this command from your ezvpn config:
re-establish your tunnel
when you do a show crypto engine connections active, what do you see?
here is a snippet from a config i use:
crypto ipsec client ezvpn hw-client
connect auto
group groupnamechanged key XXXXXXXXXXXXXXXX
mode client
peer (outside IP of 3000 Concentrator)
interface Ethernet0
ip address 172.16.1.1 255.255.255.0
no cdp enable
crypto ipsec client ezvpn hw-client inside
hold-queue 32 in
hold-queue 100 out
no ip directed-broadcast
no ip redirects
interface Ethernet1
ip access-group 131 in
ip accounting access-violations
ip inspect INPSECTIONRULES out
no cdp enable
no ip redirects
after this, if your devices can establish the tunnel but still cannot pass traffic try this to pinpoint your problem. Config split tunneling on the concentrator for that group. after you re-establish your tunnel see if your internal host (on the ezvpn client end) can get out to the Internet.
here are 2 links that helped me alot when i was setting up the RO links
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800945cf.shtml
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/products_feature_guide09186a00800a8565.html
thanks for the quick response.
ezvpn group was set up for ipsec over udp, is not now. there are no discarded ipsec packets on concentrator.
router#show crypto engin conn active
ID Interface IP-Address State Algorithm Encrypt Decrypt
5 Ethernet1 wan address set HMAC_SHA+3DES_56_C 0 0
20 Ethernet1 wan address set HMAC_MD5+3DES_56_C 0 1
21 Ethernet1 wan address set HMAC_MD5+3DES_56_C 453 0
no conflicting filters. 3005 does have a default route to internet. many software clients connec to the 3005 just fine as well. have changed the config as advised. re-established tunnel, same symptoms. no traffic through tunnel. i can generate traffic from the concentrator side by pinging the ip associated with the session and see bytes transmitted increase, but bytes received stays at zero.
i will try the split tunneling when i get home.
on my 831 router, when i try to ping a private address on my lan behind the concentrator, i get a reply from somewhere in the at&t broadband network, which i can see through a trace. traffic seems to be going out to the local isp rather than through the tunnel. however i cannot hit any internet sites through exporer nor can i ping from a client behind the router. split tunnel is not enabled.
any ideas anyone?
thanks.
define an access-list that allows esp and place it on an outside int
it looks like your key establishes fine, but cannot pass traffic
here is a snippet of a config i use at remote sites, the ip's have been substitiuted with devices, hope this helps
access-list 133 deny ip 224.0.0.0 31.255.255.255 any log
access-list 133 deny ip 127.0.0.0 0.255.255.255 any log
access-list 133 deny ip 10.0.0.0 0.255.255.255 any log
access-list 133 deny ip 192.168.0.0 0.0.255.255 any log
access-list 133 deny ip 172.16.0.0 0.15.255.255 any log
access-list 133 deny ip 192.0.2.0 0.0.0.255 any log
access-list 133 permit icmp host MAINSITE-HEADEND-DEVICE any
access-list 133 permit icmp host VPN-CONCENTRATOR-OUTSIDE any
access-list 133 permit icmp INTERNAL-MAINSITE-LAN any
access-list 133 permit tcp host MAINSITE-HEADEND-DEVICE any eq 22
access-list 133 permit udp host MAINSITE-HEADEND-DEVICE any eq 22
access-list 133 permit tcp host MY-PC@MAINSITE any eq 22
access-list 133 permit udp host MY-PC@MAINSITE any eq 22
access-list 133 permit udp host VPN-CONCENTRATOR-OUTSIDE eq isakmp any
access-list 133 permit udp MAINSITE-INTERNAL-LAN eq isakmp any
access-list 133 permit esp host VPN-CONCENTRATOR-OUTSIDE any
access-list 133 permit esp MAINSITE-INTERNAL-LAN any
access-list 133 deny ip any any log
interface ethernet 1
ip access-group 133 in
you may want to readjust the icmp parameters to allow for pinging on the Internet
In the >crypto ipsec client ezvpn VPN
set >mode network extention, if you want to be able to ping/access
LAN from 3005 side.
brgds
Mats
99
