Community Member
EasyVPN and remote access VPN on same box
Is it possible to have an EasyVPN config and remote access into the same box? I tried doing this and when I do a vpnclient enable command it tells me to remote NAT (outside) 0
1 ACCEPTED SOLUTION
Re: EasyVPN and remote access VPN on same box
IOS router or PIX? EzVPN server or client?
If it's EzVPN server, then this is basically a remote access config also, so yes, you can certainly have both, in fact you only need to configure one and you get the other anyway.
If it's EzVPN client, then no if it's a PIX, and yes if it's a router but you have to be running 12.2(15)T, see http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t15/ftezvpnr.htm#1155828 for details.
Please reply back with more information on exactly what you're trying to do, it's a little unclear from your initial explanation.
Community Member
Thanks. I appreciate it. I was trying to make an EzVPN client a RAS VPN as well.
AZ
102
