EasyVPN woes
Hey all,
I have easyvpn setup for network extension mode between my site and a remote site. This is what it looks like in a nutshell.
My End
Router
= VPN Tunnel
= Internet
Remote PIX501
Remote Router
Remote LAN
As you can see the remote site's internet and vpn tunnel are from the same interface on the pix.
Basically when the Local LAN is connected directly to the PIX, internet fails but the vpn tunnel works. If the router is added, nothing works. However, if I bring down the vpn tunnel and the router is added, then internet works fine.
Here is the config I had them input at the remote PIX501:
vpnclient server [my public interface]
vpnclient mode network-extension-mode
vpnclient vpngroup groupname password blahblah
vpnclient username someuser password blahblah
Here is my current ocnfig of my router:
aaa new-model
aaa authentication login localuser local
aaa authorization network NSSOLVPN local
aaa session-id common
resource policy
no network-clock-participate slot 1
no network-clock-participate wic 0
ip subnet-zero
no ip dhcp use vrf connected
username [snip] password 7 [snip]
controller T3 1/0
cablelength 10
description MCI DS3 W0M95313
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp keepalive 90 12
crypto isakmp xauth timeout 60
crypto isakmp client configuration group vpngroup
key [snip]
dns 192.168.x.x 192.168.x.x
wins 192.168.x.x 192.168.x.x
pool vpn-pool
acl 104
save-password
crypto ipsec transform-set TRANSFORM-1 esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set TRANSFORM-1
reverse-route
crypto map dynmap client authentication list localuser
crypto map dynmap isakmp authorization list vpngroup
crypto map dynmap client configuration address respond
crypto map dynmap 10 ipsec-isakmp dynamic dynmap
interface FastEthernet0/0
interface FastEthernet0/1
interface Serial1/0
bandwidth 44210
ip address mypublicinterface 255.255.255.252
ip verify unicast reverse-path
ip virtual-reassembly
rate-limit input access-group 102 3000000 562500 1125000 conform-act
e exceed-action drop
rate-limit input access-group 105 3000000 562500 1125000 conform-act
encapsulation ppp
ip route-cache flow
keepalive 8 3
dsu bandwidth 6316
scramble
crypto map dynmap
ip local pool vpn-pool 192.168.1.150 192.168.1.160
ip classless
ip route 0.0.0.0 0.0.0.0 Serial1/0
ip http server
ip http secure-server
logging trap debugging
access-list 10 permit 192.168.1.0 0.0.0.255
access-list 104 permit ip remotesiteiprange 0.0.0.255 localdmziprange 0.0.0.255
snmp-server ifindex persist
I asked them to change their default gateway of their machines to point to their router and then the router's default gateway to the PIX. Same problem. :(
1 REPLY
Anonymous
N/A
Re: EasyVPN woes
Easy VPN greatly simplifies virtual private network (VPN) deployment for remote offices and teleworkers. For more details regarding the configuration of Easy VPN follow the url,
http://www.cisco.com/en/US/products/ps6659/products_ios_protocol_option_home.html
81
