EIGRP Issue Connecting Two ASA int to Two Router Int
On a router I get an EIGRP can't find upstream IP and vice versa on the ASA as I have two FA plugged into two Gig E (stepped down) on the ASA. There are two tunnels going out both interfaces but I get these errors simply pinging from the upstream routers.
Any ideas about the EIGRP error?
Re: EIGRP Issue Connecting Two ASA int to Two Router Int
Can you post the exact messages that you are seeing from the Pix and router. Also, are you trying to configure EIGRP across the IPSEC Tunnel.
Arul
EIGRP% Cannot find adjacent neigh IP address.
I have eigrp network statements on the ASA and router but I haven't configured any routing commands on the tunnel.
Heres the error message:
Feb 04 2008 18:09:22: %ASA-5-336010: EIGRP-IPv4: PDM(334 10: Neighbor 50.0.4.1 (
GigabitEthernet0/3) is up: new adjacency
The Cisco Security Appliance System Log Messages, Version 8.0
Gives me this which isn't very helpful...
336010
Error Message %ASA-5-336010 EIGRP- tableid as_id: Neighbor address (%interface) is event_msg: msg
Explanation Neighbor Change. A neighbor went up or down.
•ddb_name-IPv4
•tableid- internal ID for the RIB
•as_id-autonomous system ID
•address-IP address of the neighbor
•interface-Name of the interface
•event_msg- Event that is occurring for the neighbor (that is, "up" or "down")
•msg-Reason for the event. Possible event_msg and msg value pairs include:
-resync: peer graceful-restart
-down: holding timer expired
-up: new adjacency
-down: Auth failure
-down: Stuck in Active
-down: Interface PEER-TERMINATION received
-down: K-value mismatch
-down: Peer Termination received
-down: stuck in INIT state
-down: peer info changed
-down: summary configured
-down: Max hopcount changed
-down: metric changed
-down: [No reason]
Recommended Action Check to see why the link on the neighbor is going down or is flapping. This may be a sign of a problem, or a problem might start occurring because of this.
866
