Community Member
Enabling WebVPN
hi,
i recently upgraded my ASA 5520 from 7.0(4) to 7.2(2) cause we wanted to try out WebVPN.
i configured using a couple of sample confgs from cisco and was able to setup a SSL VPN Client setup.
However one of the sample cofigs was for Clientless SSL VPN setup.
how do i go about to set up a Clientless SSL VPN ? im assuming that if i Disable the
Configuration > WebVPN > SSL VPN Client > Enable option
then should it work ? cause i already have the portal page set up with Server URLs n everything else i hope, but when i login it creates a SSL VPN Client connection (displays a yellow key in the task bar)
Any comments.. ?
1 REPLY
Bronze
Re: Enabling WebVPN
You have to edit your WebVPN Group Policy:
Go to Configuration > VPN > General > Group Policy > WebVPN > SSL VPN Client
Once there, you can enable or disable the use of the SSL VPN Client. In your case, check the radiobutton 'Never'.
The WebVPN will now never use the SSL VPN Client, unless you change the Group Policy again :)
Please rate if the post helps!
Michael
216
