11-21-2005 08:59 PM - edited 02-21-2020 02:07 PM
I have to set up a VPN tunnel between pix 535 and cisco vpn concentrator 3000 series.
There is a problem on the pix 535 side. No packets are being encrypted and sent to the vpn concentrator's end.
Pix has multiple SA's for the same tunnel on PIX. Packets are being decrypted by the pix.
I see transmitted packets but no revceived packets on the vpn concentrator.
here is the configuration on the pix:
isakmp key ******** address 202.125.152.200 netmask 255.255.255.255
isakmp policy 20 encrypt des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp enable outside
access-list inside_outbound_nat0_acl line 1 permit 10.0.1.1 255.255.255.255 192.168.5.1 255.255.255.255
nat (inside) 0 access-list inside_outbound_nat0_acl
access-list outside_cryptomap_20 permit ip 10.0.1.1 255.255.255.255 192.168.5.1 255.255.255.255
crypto map outside_map 20 set peer 202.125.152.200
crypto map outside_map 20 match address outside_cryptomap_20
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto map outside_map 20 set transform-set ESP-DES-MD5
crypto map outside_map 20 set security-association lifetime seconds 28800
crypto map outside_map interface outside
sysopt connection permit-ipsec
I see hits on the inside_outbound_nat0_acl Access list. There are not hits on the outside_cryptomap_20 access list.
thank you
11-22-2005 01:51 PM
The local host 10.0.1.1, does it have a route to the 192.168.5.1 host via the PIX inside interface?
11-22-2005 10:43 PM
yes the local host 10.0.1.1 has a route to 192.168.5.1. Moreover it send icmp reply back to that host which is filtered by pix and not sent any further to the other end
11-24-2005 01:00 AM
Hi All,
I may be off here, but, the entries look different to me.
If I'm wrong, sorry. Cheers.
coolboarderguy...
11-24-2005 04:17 AM
hello all,
thanks for ur replies. The issue was with PIX and has been fixed. i've changed the nat 0 to static translation and used NAT traversal at the vpn concentrators end.
peace
