erase flash question
I'm drafting some ASA rollout procedures and wanted to document a build from scratch. Using a test ASA5520, I booted into monitor mode and erased the flash, with the expectation that I would be able to upload the latest image release onto the unit. I can xfer the latest 8.0(3) image onto the unit via monitor mode tftp, but after the unit boots up, it seems as if the flash is corrupted. sh ver detects 256MB, but the flash seems to be unwritable/unavailable.
sh ver after boot:
ciscoasa(config)# sh ver
Cisco Adaptive Security Appliance Software Version 8.0(3)
Compiled on Tue 06-Nov-07 22:59 by builders
System image file is "tftp://164.84.203.19/asa803-k8.bin"
Config file at boot was "startup-config"
ciscoasa up 15 mins 34 secs
Hardware: ASA5520, 512 MB RAM, CPU Pentium 4 Celeron 2000 MHz
Internal ATA Compact Flash, 256MB
BIOS Flash M50FW080 @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-55x0 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.01
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Ext: GigabitEthernet0/0 : address is 001d.a259.4d92, irq 9
1: Ext: GigabitEthernet0/1 : address is 001d.a259.4d93, irq 9
2: Ext: GigabitEthernet0/2 : address is 001d.a259.4d94, irq 9
3: Ext: GigabitEthernet0/3 : address is 001d.a259.4d95, irq 9
4: Ext: Management0/0 : address is 001d.a259.4d96, irq 11
5: Int: Not used : irq 11
6: Int: Not used : irq 5
The Running Activation Key is not valid, using default settings:
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 150
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Disabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 750
WebVPN Peers : 2
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
This platform has an ASA 5520 VPN Plus license.
Serial Number: JMX1203L123
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000 0x00000000
Configuration register is 0x1
Configuration has not been modified since last system restart.
dir shows the following after boot:
ciscoasa(config)# dir
Directory of disk0:/
421 drw- 0 13:53:02 Apr 01 2008 crypto_archive
415 drwx 0 13:52:51 Apr 01 2008 log
0 bytes total (0 bytes free)
ciscoasa(config)#
while trying to fsck shows the following:
ciscoasa(config)# fsck flash:
Unsupported file system type!
%Error checking flash: ()
ciscoasa(config)# fsck disk0:
%Error checking disk0: ()
ciscoasa(config)#
I'm guessing that the monitor mode erase renders the flash somehow unusable, but I'm hoping that there may be some way to format it for use again. Any suggestions?
Tariq
1 REPLY
Re: erase flash question
Found it - I needed to use the "format" command on the flash to make it usable again.
Tariq
1068
