Community Member
Error 442 while Virtual Adapter is part of a Network Bridge
I am trying to bridge my LAN port to the VPN Adapter, however when I try to connect to the VPN, the Client responds with Error 442. What should I do to remedy this?
For background, I am trying to connect an internet phone to the internet through my computer. My computer connects via wireless to a network, which then requires the VPN to connect to the outside internet. My goal is to configure my computer so that my LAN port functions just as a port on a router would, and have the VPN client function normally.
Please advise on the best way to do this. on Windows XPsp2.
Thank you,
Jonathan
1 REPLY
Bronze
Re: Error 442 while Virtual Adapter is part of a Network Bridge
Reason 442: Failed to enable virtual adapter.
Description or Action:
Attempt a reboot before trying again. Or go to network connection property pages and try to manually enable/disable the _Cisco Systems VPN Adapter_. Also try to add the following line to vpnclient.ini: [main] VAEnableAlt=0.
208
