03-25-2006 07:28 AM - edited 02-21-2020 12:47 AM
Configuration shows
ERROR: Command requires failover license
6.3 config
ip audit name info-sign info action alarm
ip audit name attack-sign attack action reset
ip audit interface outside info-sign
ip audit interface outside attack-sign
ip audit attack action reset
ip audit signature 2000 disable
ip audit signature 2004 disable
pdm logging informational 100
pdm history enable
arp timeout 14400
7.0(4) config
icmp permit 192.168.11.0 255.255.255.0 inside
icmp permit 192.168.11.0 255.255.255.0 dmz
asdm history enable
arp timeout 14400
Not able to determine to which command the
error is referring to.
03-26-2006 08:37 PM
It's the failover commands, which since you don't have a failover license you don't need to worry about :-)
There was some change in the 7.0 code that makes these errors come up since there's a couple of failover commands that are default in the config, but they're purely cosmetic and not anything to worry about.
See bug http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsc23718&Submit=Search, fixed in the next version so once you upgrade they won't be there anymore.
03-30-2006 09:26 AM
Thank you for your response.
It allows me to go ahead with upgrading the remaining
units.
