Community Member
Error message on Updating Sensor with IDSk9-sp-3.0-5-S17.bin
Sucessfully Updated sensor with IDSk9-sp-3.0-4-S16.bin. Could not updated sensor with IDSk9-sp-3.0-5-S17.bin. Both files were downloaded in the same manner and transfered to the sensor.
Here is the following error message:
# ./IDSk9-sp-3.0-5-S17.bin -I
Invalid character (0x0) on line 39935
No end line
tar: read error: unexpected EOF
chmod: WARNING: can't access ./SEN305SP/install/ids-patchinstall
Files were downloaded from Cisco's http download site. Downloaded the S17 release twice same error occurs. Is there a problem with the file?
Community Member
Re: Error message on Updating Sensor with IDSk9-sp-3.0-5-S17.bin
I had no problems using all of the files off of Cisco's site, including S17..
Community Member
Verify checksums for the file you downloaded match the values listed on the software download page to make sure the file was tranferred successfully.
Community Member
Thank you, for the confirmation that the file worked for someone. I re-downloaded the file and ensured the checksums matched. It executed as expected.
93
