Error msg when running sysconfig-sensor
I'm trying to run sysconfig-sensor and get an error msg after I enter the values for option 6, communications infrastructure. The error basically says the eventd.conf file cannot be modified because it's a read only file system. Please see below for a screen shot of the error. Also, when I enter the nrvers command I get another error. Please see other msg below. Do I have to run the recovery CD? Why is this happening?
SYSCONFIG-SENSOR ERROR MESSAGE:
Making sure the IDS daemons are stopped before creating the configuration
files...
Assertion failed: semaFd != -1, file WgcSema.cpp, line 461
/usr/sbin/sysconfig-sensor[9]: 759 Abort(coredump)
Warning! /usr/nr/bin/nrstop returned error code 134!
Creating configuration files...
cp: cannot create /usr/nr/etc/eventd.conf: Read-only file system
ERROR: Could not create /usr/nr/etc/eventd.conf
NRVERS ERROR MESSAGE:
netrangr@PCICORBY-XXXXXXXX-x-UK:/usr/nr
>nrvers
Application Versions for PCICORBY-XXXXXXXXX-x-UK.mfg
The Version of the Sensor is: 3.0(2)S11
1 REPLY
Re: Error msg when running sysconfig-sensor
This doesn't look good, did you lose power or anything like that to this site? Plug a keyboard and monitor into the sensor and do an "init 6" on it to reboot, do you get any error messages? You might try running "fsck" on it a few times, but to be honest, when you start having problems like this the recovery CD is usually where you end up.
97
