Error on 6509 Chassis
I am getting the logs below on my 6500. what cisco is saying if it happens once then just ignore it. I am getting the logs below everyday.
Mar 18 02:42:55 GMT: %SYSTEM_CONTROLLER-3-COR_MEM_ERR: Correctable DRAM memory error. Count 377, log E183B720
Mar 18 08:23:53 GMT: %SYS-5-CONFIG_I:
Mar 19 23:51:01 GMT: %SYSTEM_CONTROLLER-3-COR_MEM_ERR: Correctable DRAM memory error. Count 378, log E183B720
Mar 25 17:56:09 GMT: %SYS-5-CONFIG_I:
Mar 25 18:22:58 GMT: %SYSTEM_CONTROLLER-3-COR_MEM_ERR: Correctable DRAM memory error. Count 379, log E183B720
Mar 25 19:22:58 GMT: %SYSTEM_CONTROLLER-3-MORE_COR_ERR: 1 correctable DRAM memory errors in previous hour
Mar 25 19:22:58 GMT: %SYSTEM_CONTROLLER-3-COR_MEM_ERR: Correctable DRAM memory error. Count 381, log E183B720ay.
1 REPLY
Silver
Re: Error on 6509 Chassis
The message indicates a correctable DRAM memory error, usually if this error happens once or twice, no action is required but if it happens more than that then try reseating the DRAM memory chip on the board. Since it is a correctable error you can continue to use the board.
375
