Error when telnet/PDM from VPN tunnel to inside management IP
Hoping someone has the answer to this...
When I connect from the Internet to the PIX using an IPSec tunnel, I can access all internal hosts and services. However, I am unable to manage the PIX.
If I telnet, I get this error:
telnet 192.168.1.1
Connecting To 192.168.1.1...Could not open connection to the host, on port 23.
No connection could be made because the target machine actively refused it.
The PIX is running 6.3(1) and has the "management-access inside" command.
Gold
Re: Error when telnet/PDM from VPN tunnel to inside management I
Hello Pierre,
Please read the following document on Telnet access via IPSec for PIX v6.3 - Hope this helps - Jay.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_command_reference_chapter09186a00801727ae.html#1025921
Thanks Jay,
I am familiar with the command reference but I am not understanding what exactly I need to do to enable this. I added the IP pool subnet that is assigned to VPN clients but it still does not work. I also tried telnet with the outside IP address of the pix and it does not work either.
What am I missing?
Pierre
Silver
Can you post your telnet lines from your pix config?
As of right now, the running configuration is as follows... I included the relevant VPN commands as well.
access-list acl_crypto permit ip any 10.1.1.0 255.255.255.224
access-list acl_split_tunnel permit ip 192.168.1.0 255.255.255.0 any
access-list acl_no_nat permit ip 192.168.1.0 255.255.255.0 10.1.1.0 255.255.255.
224
ip local pool vpnpool 10.1.1.1-10.1.1.10
nat (inside) 0 access-list acl_no_nat
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto dynamic-map outside_dyn_map 20 match address acl_crypto
crypto dynamic-map outside_dyn_map 20 set transform-set ESP-3DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map
crypto map outside_map client authentication LOCAL
crypto map outside_map interface outside
isakmp enable outside
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption 3des
isakmp policy 20 hash md5
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
vpngroup xxxxxxxxx address-pool vpnpool
vpngroup xxxxxxxxx dns-server 192.168.1.41
vpngroup xxxxxxxxx default-domain xxxxxxxxxxxxxx.com
vpngroup xxxxxxxxx split-tunnel acl_split_tunnel
vpngroup xxxxxxxxx split-dns xxxxxxxxxxxxxx.com
vpngroup xxxxxxxxx idle-time 1800
vpngroup xxxxxxxxx password ********
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
Thanks!
Silver
You might need to add a telnet line for the netblock you are connecting from :
If you are connecting from 1.2.3.4/24, via the outside interface:
telnet 1.2.3.0 255.255.255.0 outside
Well, I never know where I will be connecting from because it is usually on dial-up. However, I do know that it's through VPN (10.1.1.0/27). And I did add "telnet 10.1.1.0 255.255.255.224 outside" but that did not help.
Maybe I should open a TAC case?
To the PIX the telnet connection looks like it comes from the IP pool on the inside interface, so you have to add the command:
> telnet 10.1.1.0 255.255.255.224 inside
for this to work. I just tried it on my lab PIX and it works fine.
Just did that and it worked. Thanks a lot!
142
