Community Member
ESMTP Inspection Dropping Connections
I am trying to understand why my ASA appears to be dropping packets with the following message
%ASA-4-108004: ESMTP Classification: Dropped connection for ESMTP Request from inside:1.1.1.1/1292 to DMZ:2.2.2.2/25; matched Class 31: cmd RCPT count gt 100
My understanding is that the "RCPT count gt 100" drops connections if the number of recipients is gt 100. I have a wireshark trace of this transaction and there is only 1 recipient on this email.
This makes no sense to me. Why else would I be seeing this message if the number of RCPT To addresses is 1? Does this have anything to do with the number of length of the RCPT TO email address?
Thanks.
Can you paste your class-map and policy map output here?
Warm regards, Ramraj Sivagnanam Sivajanam Technical Specialist/Service Delivery Manager – Managed Service Department
Community Member
policy-map type inspect esmtp esmtp_map
parameters
match cmd line length gt 512
  drop-connection log
match cmd RCPT count gt 100
  drop-connection log
match body line length gt 998
  log
match header line length gt 998
  log
match sender-address length gt 320
  drop-connection log
match MIME filename length gt 255
  drop-connection log
match ehlo-reply-parameter others
  mask
Community Member
The output I see is in the original message (so I don't have to go retrieve it again ). The map is the same as the default ESMTP inspection map except I removed "drop-connection" from the "match header line length gt 998" while we do some testing.
1277
