Community Member
Establish a VPN and Get an IP, but no traffic to inside allowed
Hello all, I have a PIX 506 with 6.3.4 and I terminate IPSEC based vpn on it. I get an IP address when I establish the VPN, but I cannot ping or communicate with any of the internal network. I know I am missing something simple, but I just can't seem to find it. Your help is appreciated. My config is below.
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password XXXXXXXXXX
passwd XXXXXXXXXRRRRR encrypted
hostname business
access-list out_in permit tcp any any eq 995
access-list split_tunnel permit ip
access-list nonat permit ip
pager lines 24
logging monitor debugging
mtu outside 1500
mtu inside 1500
ip address outside
ip address inside
ip audit info action alarm
ip audit attack action alarm
ip local pool ippool
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list nonat
nat (inside) 1 0 0
static (inside,outside) tcp interface smtp smtp netmask 0 0
static (inside,outside) tcp interface 3389 3389 netmask 0 0
static (inside,outside) tcp interface https https netmask 0 0
static (inside,outside) tcp interface 995 995 netmask 0 0
static (inside,outside) tcp interface 3390 3389 netmask 0 0
access-group out_in in interface outside
route outside 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
aaa-server w2k3 protocol radius
aaa-server w2k3 max-failed-attempts 3
aaa-server w2k3 deadtime 10
aaa-server w2k3 (inside) host radkey timeout 10
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set ESP-AES-192 esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto dynamic-map dynmap 10 set transform-set ESP-3DES-SHA
crypto map mymap 10 ipsec-isakmp dynamic dynmap
crypto map mymap client authentication w2k3
crypto map mymap interface outside
isakmp enable outside
isakmp identity address
isakmp keepalive 10
isakmp nat-traversal 20
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 86400
isakmp policy 20 authentication pre-share
isakmp policy 20 encryption aes-256
isakmp policy 20 hash sha
isakmp policy 20 group 2
isakmp policy 20 lifetime 86400
isakmp policy 30 authentication pre-share
isakmp policy 30 encryption des
isakmp policy 30 hash sha
isakmp policy 30 group 1
isakmp policy 30 lifetime 86400
vpngroup business address-pool ippool
vpngroup business dns-server
vpngroup business default-domain business.local
vpngroup business split-tunnel split_tunnel
vpngroup business split-dns business.local
vpngroup business idle-time 1600
vpngroup business password ********
telnet inside
telnet timeout 5
management-access inside
Re: Establish a VPN and Get an IP, but no traffic to inside allo
try applying these commands:
crypto map mymap client configuration address initiate
crypto map mymap client configuration address respond
