Establish tunnel from 3005 concentrator to remote router
I have 1700 routers configured for IPSec, preshared keys, 3DES to connect to a 3005 concentrator. The connection from the 1700 to the concentrator works fine. However, I cannot establish a connection from the concentrator private network to the 1700. Any suggestions???
Thanks.
1 REPLY
Re: Establish tunnel from 3005 concentrator to remote router
Hi Eric,
Make sure that the IPSec traffic on both the sides is a Mirror image of eachother. Follow the sample at: http://www.cisco.com/warp/public/471/ALTIGAR.shtml if you haven't done that already. Additionally you are trying to send traffic from the Private networks, correct?
Hope this helps,
Aamir
104
