05-16-2006 06:57 AM - edited 02-21-2020 12:54 AM
Dear friends,
I'm trying to deploy a solution of webmail using MS Exchange 2000 (front-end and back-end servers). However, I could not install MS EXCH on front-end server (located in DMZ) because it's not reaching the domain controller on INSIDE.
I read all MS documentation about installing this type of program, but it didn't solve my problem.
What must I have to put on PIX settings to permit my Front-end server to reach the DC on the inside network?
I appreciate your help.
P.S: My PIX is 515E and using 7.0 version
05-16-2006 07:28 AM
Hello :
This articles on subject should serve as a guide.
They are from a previous version but the configuration is practically the same.
Post some more info on your particular project, ip addresess, actual pix configuration.
http://www.cisco.com/univercd/cc/td/doc/ product/iaabu/pix/pix_62/config/msexchng.pdf
Hope this helps ...
05-17-2006 04:27 AM
Federico,
I appreciate your help. However, the documents you were referencing suppose that I already istalled MS Exchange. I didn't do it yet. I need a help exactly on this point, that is, how to install Exchange in front-end configuration if PIX is between it and the Back-end Exchange server. I guess there is something like a script. Do you have some other reference?
Mauricio
05-17-2006 04:48 AM
Hello
I am sorry I can not help you with that script you mention to install Exchange service.
I believe that particular issue is out of the scope of this forum.
Have a great day !
05-31-2006 01:43 PM
hi
i had exactly the same problem but it is really quite easy to sort out let me have your email address and i will email you back with an attachment that will explain fully what you have to do
regards
melvyn brown
05-31-2006 04:10 PM
Melvyn,
I appreciate your help but, in fact, I already solved my problem. It was related to an Exchange configuration involving Active Directory sites. I put the Exchange front-end server inside the correct AD site and everything was ok.
By the way, if you can, please, send the document to this address: superharley@hotmail.com.
Thank you.
