extendable
in the ip nat source static in my router, there is the EXTENDABLE option after the port number..what is the equivalent of that in my PIX? I have to permit the same in my firewall.
Thanks a lot.
  • Other Security Subjects
Gold
Re: extendable
Hello Erwin,
The answer to your question is ‘static translation’(see point 2 below) – the static cmd is used to map outside address to the inside address and you’ll need a access-list (ACL) to allow the outside traffic into your inside network.
What sort of service are you trying to permit via your firewall? What PIX IOS are you running? If it’s any of the following services then please use the ACL’s below.
The best way to write the ACL would be on a text-editor first such as notepad and then use copy and paste back onto the PIX config, makesure that you are in PIX config mode. Also, remember to save your config with cmd : ‘wr m’ (write memory), and remember to place a ‘no access-list outbound’ cmd as the first line of your modified ACL, this way when you paste back the ACL the old copy (if any) will be replaced correctly with the new copy of the ACL.
Use cmd ‘clear xlate’ after you have made the modifications on your PIX.
The ACL’s below are for ‘www’ access, https access, pop3/smtp access and domain access, you can modify them for your own use.
If you need to let traffic back in then please follow the instructions on point 2 below.
1 - ACL for outbound connections:
access-list outbound remark www
access-list outbound permit tcp 192.168.10.0 255.255.255.0 any eq www
access-list outbound permit tcp 192.168.10.0 255.255.255.0 any eq https
access-list outbound remark email
access-list outbound permit tcp 192.168.10.0 255.255.255.0 any eq pop3
access-list outbound permit tcp 192.168.10.0 255.255.255.0 any eq smtp
access-list outbound remark ns
access-list outbound permit tcp 192.168.10.0 255.255.255.0 any eq domain
access-list outbound permit udp 192.168.10.0 255.255.255.0 any eq domain
access-group outbound in interface inside
If you use inside local servers (proxy, NS, SMTP) use only host address in these access-lists.
2 - SMTP
Don’t forget to open inbound connection for incoming emails on outside interface.
static (inside,outside) 192.168.10.x netmask 255.255.255.255
access-list inbound permit tcp any host eq smtp
access-group inbound in interface outside
Hope this helps -
Re: extendable
I dont have any problem with what you have discussed above..My only concern as i've posted on my original queery is the counterpart in PIX of the EXTENDABLE port option in the router. The router has the ff. command
ip nat source static tcp 192.168.150.1 397 IP(public) 397 extendable
How will i allow the same in my PIX
Thanks.
Re: extendable
Sorry to interupt here, but what does "extendable" mean? I had to use it to get static nat working on my router, but I don't know why or what it does..(?)
287
