Extendable
What does "extendable" mean? I had to use it to get static nat working on my router, but I don't know why or what it does..(?)
ip nat inside source static tcp [inside ip] 80 [outside ip] 80 extendable
1 ACCEPTED SOLUTION
Silver
Re: Extendable
The extendable keyword allows the user to configure several ambiguous static translations,
where an ambiguous translations are translations with the same local or global address.
ip nat inside source static extendable
Some folks want to use more than one service provider and translate into each provider's
address space. You can use route-maps to base the selection of global address pool on
output interface as well as an access-list match. Following is an example:
ip nat pool provider1-space ...
ip nat pool provider2-space ...
ip nat inside source route-map provider1-map pool provider1-space
ip nat inside source route-map provider2-map pool provider2-space
route-map provider1-map permit 10
match ip address 1
match interface Serial0/0
route-map provider2-map permit 10
match ip address 1
match interface Serial0/1
Once that is working, folks might also want to define static mappings for a particular
host using each provider's address space. The software does not allow two static
translations with the same local address, though, because it is ambiguous from the
inside. The router will accept these static translations and resolve the ambiguity by
creating full translations (all addresses and ports) if the static translations are
marked as "extendable". For a new outside-to-inside flow, the appropriate static
entry will act as a template for a full translation. For a new inside-to-outside flow,
the dynamic route-map rules will be used to create a full translation.
1 REPLY
Silver
Re: Extendable
match ip address 1
match ip address 1
439
