external.if configuration not loaded
Has anyone come across this error message 'external interface not loaded ' on a firewall.The fierwall is actually a nokia ip330.What gives me concern is the physical interface is up but i cannot icmp replys from this interface....Any ideas anyone?
1 REPLY
Re: external.if configuration not loaded
I dont know what the error message you are getting means but you should be ale to ping the firewall if one of the two following conditions exists.
- Under properties the "Accept ICMP" is set to first.
- There is a specific rule in the rulebase allowing ICMP to the firewall
105
