EzVPN between pix 501 and pix515
I have a EZVPN tunnel between a remote site (501) and the central site (515). I would like to send the syslog messages from the remote site to the syslog server at the central site in the EZVPN tunnel.
Is this possible?
Tom
1 REPLY
Re: EzVPN between pix 501 and pix515
Should be. PIX EzVPN client should automatically build an IPSec SA from it's outside interface to the remote networks, so if you just do:
> logging host outside
then it should automatically send syslog messages out with it's outside IP address as the source, and because of the SA's it builds, they should be encrypted and sent over the tunnel.
Check on the central 515 (sho cry ipsec sa) and you should see an SA built from the 501's outside interface to the subnet behind the 515, if you see that then configuring the 501 with the above command should be all you need.
81
