EzVPN Client Problem. IPSec blackhole
We have a 2811 router acting as an Easy VPN Server (12.4(4)T) and 831 routers acting as Easy VPN Clients (In auto, network-extension mode) running version 12.3(11)T7. All the routers have "isakmp invalid-spi-recovery" enabled.
However quite frequently the the Easy VPN Client router gets stuck in sort of a black hole, when the IPSec SA are deleted\gone, while the ISAKMP SA is still active.
On the Hub router side, both ISAKMP and IPSec SA are active.
In this scenario, the Client router doesn't try to re-negotiate the IPSec SA and therefore no traffic flows. Doing a "clear isakmp sa" fixes the issues as then Phase1\2 are re-negotiated.
I thought that "invalid-spi-recovery" command was specifically for this purpose ?
How can i fix this issue that the client router detect the clearing of IPSec SA and then should automatically re-negotiate ?
Naman
Gold
Re: EzVPN Client Problem. IPSec blackhole
try applying the command "crypto isakmp keepalive".
That command is already there. As i said that the ISAKMP SA stay alive, the problem is with the IPSec SA.
Since the ISAKMP SA stay alive, and connection is present between the peers, the keepalive messages doesn't detect any problem.
\\ Naman
Silver
crypto ipsec security-association idle-time 60. Check if this solves the issue. It will tear the ISAKMP and IPSEC if the session is idle for 60 secs
Will give this a try.
Thanks.
226
