EZVPN Event: MTU_CHANGED and not SOCKET_UP
When I do the "show crypto ipsec client ezvpn".. it seems that my ezvpn is stuck at:
Current State: IPSEC_ACTIVE
Last Event: MTU_CHANGED
I believe the last event should be SOCKET_UP?
EZVPN is up and "show crypto isakmp sa" and also "show crypto ipsec sa" gives a positive result. QM_IDLE as well packets are encrypted and decrypted.
What's this MTU_CHANGED and how can i actually correct this back to SOCKET_UP? Can't find any reference on what does these events mean.
Thanks.
1 REPLY
Re: EZVPN Event: MTU_CHANGED and not SOCKET_UP
It's most likely that this event means that the EzVPN peers have renegotiated a new MTU between them. If the VPN works as expected, I wouldn't worry about it, but if you're concerned, you could work out the MTU of the link and specify it on the relevant interfaces.
Cheers,
563
