Community Member
EZVPN in a spoke to spoke configuration
I have remote 851 routers that will get dynamic IP addressing from the ISP. These 851's will terminate their vpn connection into an ASA5520 that gets static IP addressing from the ISP. I had started to look into L2L Dynamic VPN's but was told that it is best to use EZVPN. My question is, can EZVPN allow our remote 851 routers communicate with each other in a spoke to spoke configuration (Cisco Hairpinning)?
1 REPLY
Silver
Re: EZVPN in a spoke to spoke configuration
Router 851 supports your needs , for EZVPN configuration use the Cisco 800 Series Routers Configuration Examples and TechNotes
http://www.cisco.com/en/US/products/hw/routers/ps380/tsd_products_support_configure.html
240
