EZVPN - Oracle Problem
We have a 10 sites with Pix 501 configure with EZVPN and they all terminate to Cisco 3030 concentrator. We have few users in one of this sites, and this is the only site that are constantly accessing Oracle databases which is siting in a network behind the concentrator. That problem is that they are only getting disconnected from the Oracle server, but every other applications like mail, internet access still works. I can say that the problems is the Oracle server because they never had this problem when they were on the frame-relay. Any suggestion would be appreciate. Thanks in advance
Re: EZVPN - Oracle Problem
Enable syslogging on the local PIX and check for messages when they get disconected. Do all the users get disconnected at once (indicating a problem with the tunnel perhaps), or is it just one at random times?
Gullage -
Users are getting disconnected randomly and stays up because users are still able to access e-mail and internet access.
But I will definetly enable syslog as you suggested.
Thanks.
98
