EzVPN Over T1 on 2600
Hi Guys,
I have a 2600 im needing to setup ezvpn on over a T1 port, however it seems like my IOS does support the crypto command so im thinking i need a newer IOS to do this since there are threads where others have done this. The IOS im using is 12.1(3r) T2, whats the version ill need to do this?
Also just want to make sure that it is possible to do this with the 2600, if not can some suggest a simple router that supports T1 and will connect to my 2600 or replace it and give me the functionality that i need?
Thanks!
Silver
Re: EzVPN Over T1 on 2600
Yes configuring EZVPN over T1 is an allowed configuration. This is supported on the 2600 router.
Thank you, i found that ill need to get IOS 12.2 but will need to upgrade my flash and DRAM first.
124
