ezvpn to 2 separate headends from 1 vpn remote
hi,
i'd like to ask if the following scenario is possible (according to cisco docs it is):
i need to initiate 2 ezvpn tunnels from location A (LAN1), to locations B (LAN2) and C (LAN3).
i read on several docs that with the DVTI functoinality is posible. particularly i used this document:
http://www.cisco.com/en/US/products/ps6635/products_white_paper0900aecd8039e301.shtml
i followed it step by step and this doesn't seem to work. the remote router keeps pushing ipsec traffic through the first tunnel (LAN1<--->LAN2), even though the tunnel to LAN3 is up and running. i tried several split-tunneling scenarios (even though i'm not sure it actually applies).
i wanted to know if this scenario is actually posible and if anyone has a working config, can you please share it?
thanks in advance!
regards,
c.
1 REPLY
Silver
Re: ezvpn to 2 separate headends from 1 vpn remote
What software versions are you using in these devices?
103
