Community Member
EZVPN
When using easy vpn in nem mode it has been said that the remote site present a single routable network to the hub site.What is that mean?
Does it mean that i could directly access the pc at the remote site from the hub?
1 ACCEPTED SOLUTION
Re: EZVPN
Yes, you could directly access the PC at the remote site from the Hub. Below is some info on VPN3002 NEM and this concept should apply for all EZVPN Implementation in NEM. Also, if you chose to deploy NEM, make sure that there are no overlapping remote subnets.
Network Extension mode allows the VPN 3002 to present a single, routable network to the remote private network over the VPN tunnel. IPSec encapsulates all traffic from the VPN 3002 private network to networks behind the central-site VPN Concentrator. PAT does not apply. Therefore, devices behind the VPN Concentrator have direct access to devices on the VPN 3002 private network over the tunnel, and only over the tunnel, and vice versa. The VPN 3002 must initiate the tunnel, but after the tunnel is up, either side can initiate data exchange.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2286/products_getting_started_guide_chapter09186a008015ce60.html#1278289
Arul
** Please rate all helpful posts **
Re: EZVPN
Arul
Community Member
Re: EZVPN
What is the meaning of direct access?
Does it mean that i could use remote desktop connection to access any machine at the remote site?
Re: EZVPN
In this context direct access means that after the IPSEC Connection is established between the remote and headend side, the connection is treated as a Lan to Lan Connection. So, either side can initiate traffic.
This is in contrast with PAT Mode, where after the IPSEC Connection is established, traffic can only be initiated from the remote side.
So, to answer your specific question, Yes, after the tunnel is up in NEM, you should be able to to RDC from the Headend to the remote site.
Arul
281
