failover active
we hv primary & secondary PIX firewall.Once the active fails the secondary takes care.
After sometime when primary comes back what cmd shd i use..
failover active at Original primary PIX or at secondary(whick is active now)?.
  • Other Security Subjects
Re: failover active
The failover active command should always be issued on the firewall that is shown as the standby when you do a "show fail". So if your show fail shows that
Primary - standby
Secondary - active
Then the fail active is done on the Primary
Re: failover active
Hello...
thanks for ur info.u mean to say that if primary is under standby mode and if i want to enable to "ACTIVE"state i shd config "Failover active at the Primary PIX.correct?
thanks.....rajan
238
