10-11-2006 08:18 AM - edited 03-09-2019 04:29 PM
Running 3.1(3)
Inter-chasis failover
Active/Standby multi context mode on FWSM.
Trying to add a secondary FWSM into a inter-chasis switch config to active as standby unit. Setup primary FWSM and fail over lan link no issues. However on Secondary FW after entering the 'failover' command I get the following out:
FWSM(config)# failover
FWSM(config)# sh fai
Failover On
Failover unit Secondary
Failover LAN Interface: faillink Vlan 698 (up)
Unit Poll frequency 1 seconds, holdtime 15 seconds
Interface Poll frequency 15 seconds
Interface Policy 50%
Monitored Interfaces 0 of 250 maximum
Config sync: active
Version: Ours 3.1(3), Mate 3.1(3)
Last Failover at: 16:49:07 GMT Oct 11 2006
This host: Secondary - Disabled
Active time: 0 (sec)
Other host: Primary - Not Detected
Active time: 6288 (sec)
Stateful Failover Logical Update Statistics
Link : Unconfigured.
Then, within a few seconds the output reflect:
FWSM(config)# sh failover
Failover Off (pseudo-Standby)
And the Failover is disabled. The OS is the same as you can see from the first output and the fail over link is up and working and I can ping between the firewalls using the link.
Output of config on secondar:
failover lan unit secondary
failover lan interface faillink Vlan698
failover interface ip faillink 10.129.254.125 255.255.255.252 standby 10.129.254.126
failover
The show failover history command states:
FWSM# sh failover history
From State To State Reason
Not Detected Disabled No Error
Disabled Negotiation Set by the CI config cmd
Negotiation Cold Standby Detected an Active mate
Cold Standby Disabled HA state progression failed
Any help much appreciated..
10-17-2006 05:47 AM
Did you try power cycling the device ?
12-19-2006 08:59 AM
I have he himself problem. How is solved, reset the FWSM module, or restart all the Catalyst equipment?
12-19-2006 07:03 PM
Couple of questions here. I can't find much documentation on 'pseudo-standby'. You can ping across the vlan (698) for failover - but have you actually configured any vlans with secondary addresses and put them in for monitoring? ie:
interface inside
ip address 1.1.1.1 255.255.255.0 standby 1.1.1.2
interface outside
ip address 2.2.2.2 255.255.255.0 standby 2.2.2.3
monitor-interface inside
monitor-interface outside
Pseudo-failover is probably because you have failover configured yet no interfaces configured to actually failover (or monitored to see if they failover).
--Jason
Please rate this message if it solves some/all of your issue.
12-20-2006 02:29 AM
Yes, I ping to the IP of the LAN interface failover and to the interface of standby can be made.
Yes, I have configured any vlans with secundary address and put them in for monitoring.
What I must do? Do disabled the characteristic monitor-interface?
Regards!
12-20-2006 03:11 PM
At this point, I have to think something is wrong with one of the following
1) your failover configuration on the primary
2) your failover configuration on the secondary
3) the trunk between the to switches
4) the vlans being passed up to the firewall module.
If you're willing to post your configurations showing those pieces, we'll be able to help more.
--Jason
12-20-2006 11:44 PM
I just signed on to post this same exact question. I have just upgraded to version 3.1(3) from 2.x (failover was working) and failover will not work. After this upgrade my IPS will also not talk to the firewall. It seems that the hello messages are getting blocked. For the life of me I cannot figure out this issue.
I am using transparent mode, I use a etherchannel between my 6509's and the ports are forwarding. If I give the failover command on the standby I receive Failover off (Pseudo). If I do a failover active on the standby link both units become active and routing issues occur (obviously)...HSRP goes crazy, EIGRP loses its mine and spanning tree goes wild. Attached are my system configs.
12-22-2006 01:48 AM
You are missing state link configuration on the secondary firewall. That could be an issue, I will keep looking for any other config issues in the meanwhile.
Can you try enabling state link on secondary ? Also 3.1.4 was posted early last week.
Also, could restrict your etherchannel trunk to pass only required vlans ?
Secondary FWSM
no failover
failover lan interface faillink Vlan10
failover interface-policy 1
failover replication http
failover interface ip faillink 192.168.253.1 255.255.255.252 standby 192.168.253.2
Primary FWSM
failover
failover lan unit primary
failover link statelink Vlan11
failover interface ip statelink 192.168.253.6 255.255.255.252 standby 192.168.253.5
12-22-2006 08:25 AM
I have used the statelink on the second firewall and still no luck. You should be able to only have the fail link then the configs should sync, statelink will be added and the only difference would be which one is secondary and which one is primary. I will try to pass only required vlans between my cores.
12-22-2006 08:58 AM
Quick question....on my Core's I am using IOS Version 12.2(18)SXF6 and my SUP is a 720. When reading documentation I see this:
Required
Cisco IOS - 12.2(18)SXF2 and higher for SUP 2, 720, 32
Ciso IOS modularity - 12.2(18)SXF4 for SUP 720, 32
What is the difference bettween IOS software and IOS modulairty software?
12-22-2006 11:51 AM
IOS Modularity is a new breed of IOS softtware with dynamic reconfiguration capabilities (addition of pathes to fix an issue or backout etc, process restarts)
01-03-2007 12:49 PM
I was having the same issue with fail over and just figured out what the issue was. I had one vlan on my standby unit that wasn't pushed to the module like it was on my primary unit. This command has to be identical on both units. Once it was failover worked perfectly:
firewall vlan-group 1 2,10,11,13,14,16,17,19,26-30,110,120,130,140,150,160
firewall vlan-group 1 180,200,210,220,230,240,241,250,255,500,501,600,601,700
firewall vlan-group 1 701,710,711,910,911,966,985-991
