failover interface received tcp packet
I have 2 failover Pix 525 under version 6.1.1
we found some inbound packet
> Jul 11 07:33:53 [primary-inside.2.2] %PIX-6-302001: Built inbound TCP
> connection
> 87177438 for faddr 218.1.1.1/32932 gaddr 218.1.2.2/443 laddr 218.1.2.2/443
> Jul 11 07:33:53 [secondary-inside.2.2] %PIX-6-302001: Built inbound TCP
> connection
> 87177437 for faddr 218.1.1.10/32932 gaddr 218.1.2.2/443 laddr 218.1.2.2/443
> Jul 11 07:33:53 [primary-inside.2.2] %PIX-6-302002: Teardown TCP connection
> 87177438 faddr 218.1.1.1/32932 gaddr 218.1.2.2/443 laddr 218.1.2.2./443
duration 0:00:01 bytes 918 (TCP Reset-O)
> Jul 11 07:33:53 [secondary-inside.2.2] %PIX-6-302002: Teardown TCP connection
> 87177438 faddr 218.1.1.10/32932 gaddr 218.1.2.2/443 laddr 218.1.2.2/443
Normally, the secondary-inside just only for failover, can not handled inbound Do you think which is software bug or inbound attack
Many thanks
Re: failover interface received tcp packet
Normally, the secondary PIX will not arp for anything, unless the primary goes down and secondary will swap the IP address and MAC of the primary box, and start arping for that address.
From the logs, it looks like someone is trying to reach 218.1.2.2 on port 443 and primary pix arps for it and a connection is built up, but next thing is that it tears down the connection for some reason and Secondary PIX builts the connection for same. This could be due to Failover triggering, and perhaps you have Stateful failover so all the connections built on the primary are now going to be built on Secondary. Check to see who is the 'active' failover PIX at that time, that is where the TCP connections should be built on. Maybe your PIX is failing over to secondary.
R/Yusuf
Dear Yusuf,
I just found the bug list as
CSCdv39306 Bug Details
Headline PIX loses ARP entry for HSRP address
Product pix Model
Component other Duplicate of
Severity 2 Status Verified
First Found-in Version 4.4(1), 5.2(1), 5.3(1), 6.1(1), 6.0(1)
First Fixed-in Version 6.0(4), 6.2(1), 6.1(4), 6.2(0.227), 6.1(1.107),
6.0(1.106), 6.1(3.102), 6.0(3.101) Version help
Release Notes
Problem:
The PIX loses the default route's ARP entry to an HSRP virtual IP
address. This then causes everything at the end of the PIX to lose
connectivity to everything on the other end of the PIX. This seems to
occur in version 6.0.1. This inconsistent behavior is very difficult to
replicate and we have done so only twice. Out of many hours trying to
replicate the problem.
Solution:
There is no solution at the current time.
Workaround:
Hardcode the HSRP virtual IP/MAC address mapping using
the 'alias' option to the 'arp' command.
Do you know we hit the bug, it is because , we used the 6.1.1 & 2 internet router with HSRP.
Many thanks
KH
I don't think it is this bug you are hitting. This one is primarily if you are loosing ARP entry on the PIX for an HSRP address, which i don't think is your problem. The TCP connections built on secondary are for port 443, which is SSL and nothing to do with HSRP.
As i mentioned earlier, did you check if you have stateful failover and that if the Secondary unit is/was the ACTVIE unit at the time when you see the connections being built on secondary PIX from the logs.
R/Yusuf
Dear Yusuf,
I checked the sh failover, it is normally, no failover active counter,
By the way, is it possible to upgrade 6.2.(x) is OK, or
we shutdown the failover interface, to observed the events,
OR any method to test it.
Many thanks
KH
Dear Yusuf,
Do you have suggestion on testing,
please advise
Many thanks
KH
if you can afford to disable failover for testing, then go for it, and just ahve a single PIX with no failover cable and observe.
R/Yusuf
Dear Yusuf,
Yes, at this time, the Pix is running single unit, we power down the secondary, everthing is smooth, no customer to compliant dropping application.
Do you have any suggestion at further action.
83
