FAILOVER QUESTION
I've 2 pix 525 in failover (6.3.3)
After resync (power off then on of secondary unit) the following message appear on standby unit:
"Warning:local database is empty! Use 'username' command to define local users."
But username are defined
Does anyone help me
Bronze
Re: FAILOVER QUESTION
Check if you have the following command: "crypto map client authentication local". If LOCAL is specified and the local user credential database is empty, the warning message you are seeing is seen. You need to use the 'username password ' command to manually populate the database. For more information, please see http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/tz.htm#wp1026631
no i've not crypto map client authentication local and the database is populated for ssh purpose
89
