Community Member
Failover (up but not working???)
hi all,
i have configured failover on my 2 ASA but the secondary unit state is : (Secondary - Failed) as shown below. i have configured LAN-Based Failover and stateful failover on the same gig interface.
Could any one assist me please! Thanks...
Updated:
I have found that following information:
Licensed features for this platform:
Maximum Physical Interfaces : Unlimited
Maximum VLANs : 150
Inside Hosts : Unlimited
Failover : Active/Active
VPN-DES : Enabled
VPN-3DES-AES : Enabled
Security Contexts : 2
GTP/GPRS : Disabled
VPN Peers : 750
WebVPN Peers : 2
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
Advanced Endpoint Assessment : Disabled
UC Proxy Sessions : 2
This platform has an ASA 5520 VPN Plus license.
Does that mean that the license is the problem?
Kindly find attached the output of the show commands: (sh failover & sh failover state)
Community Member
Re: Failover (up but not working???)
Community Member
Make sure that your failover interfaces are in the up/up state, and that they are not administratively down.
Chris
Community Member
hi, according to the attached show commands the interface is up and the configuration have been successfully replicated on the secondary but the problem is that when i display the status of the failover i found that the status of the Secondary ASA is: Secondary - Failed.
when i enter the commands to switch the ASA from active to standby (no failover active) or on the other ASA (failover active) the process failed.
i'm wondering do i have to contact cisco to change the license on the ASA from Active/Active to Active/Standby as mentioned above?
Active/active failover license means that you can setup Active/active as well as Active/standby failover between the units.
Sushil
The problem here is that the management interfaces :
inside_management
management
have no link between the units.
Issue :
no monitor-interface inside_management
no monitor-interface management
Above commands would effectively stop failover machanism to monitor these two interfaces.
OTHERWISE,CONNECT CABLE BETWEEN THESE INTERFACES JUST AS WITH THE REST OF THE INTERFACES AND ASSIGN ACTIVE/STANDBY IP ADDRESSES ON INTERFACES.
Please rate if helpful
Sushil
169
