Failover
If ihace 4 PIX Firewalls of the same models and software version, and every two is a failover set, primary and secondary....
Can i exchange the two primaries, so that each one work with the secondary of the other ???
Is the license include a certain primary or not ???
  • Other Security Subjects
Silver
Re: Failover
It is not possible to have a failover bundle and use it as a primary unit, if this answers your question. If it is possible to use a unrestricted unit as a failover unit I do not know for sure, but I guess not :-(
If this does not answer your question, can you be more specific on what you want to achieve (what productnumbers you have for example)
Kind Regards,
Leo
Re: Failover
Hi Leo
First Thank you for offering help, my question is if i have:
A (Primary) + B (Secondary) = Failover Set
C (Primary) + D (Secondary) = Failover Set
Can i exchange A & C ....
I think it is poosible .....
Re: Failover
Hi Mohamed,
The primary unit in the failover pair must have a Unrestricted (UR) license. The secondary unit can have a Failover (FO) or UR license. As far as this condition is satisfied, the software version and the model are identical, itcan form a FO bundle. Please refer to the below url for more info;
http://www.cisco.com/en/US/partner/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a00800eb0c4.html
yatin
Re: Failover
Hi Yatin
Thank you very your help, i got your point .....
That was exactly what i want to know .......
82
