Filtering outbound traffic with Pix
A customer wants to lock down his open ports going outbound. It's ok to allow http, but he wants everything else closed down. I don't think this can be accomplished with the Pix, right ? I mean, if I block all ports other than say tcp 80, then when even that protocol negotiates a higher number, the connection will fail. Is there a way to do established ?
Has anyone successfully blocked IM at a minimum ?
--Jon
Re: Filtering outbound traffic with Pix
It's quite common to filter outbound traffic from the inside interface. Example:
ip address inside 192.168.1.254 255.255.255.0
access-list inside-out permit tcp 192.168.1.0 255.255.255.0 any eq www
access-list inside-out permit tcp 192.168.1.0 255.255.255.0 any eq 443
access-group inside-out in interface inside
This would block all outbound traffic except ports 80 (www) and 443 (secure www)
And the Pix is then capable of handling the connection when it handshakes to a higher port ??? Does the pix bypass the acl once the traffic is established ?
That entire process happens after the access list is checked, so it's not affected.
Bob
105
