Firewall Blade on CIsco 6500
If I have a firewall Blade on 6500, How do I have the Statefull Inspection enable & implement CBAC functions..
Any URLs or Any PDFs
regards,
KCS Balaji
Re: Firewall Blade on CIsco 6500
If you have FWSM on the switch, the fixup protocol is enable by default which has the same function as inspection for CBAC on router.
Tony
Thanks for your reply.. As I was on long leave I could not reply. Does FWSM even support Full stateful inspection between the VLANs of the L3 switch by default or we have to enable them..
regards,
KCS Balaji
The Stateful Inspection Algorithm on the FWSM is called ASA, and yes it is enabled by default
you can get more info here http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_60/config/intro.htm#xtocid3
Hello.
You have to specify also which VLAN will be virtually connected to FWSM.
You can do it by entering
a) when you MSFC operates under IOS:
firewall vlan-group
firewall module vlan-group
b) when your MSFC operates under CatOS:
set vlan firewall-vlan
315
