Community Member
Firewall port 80 opened on external interface issue
I can't seem to find why port 80 and 21 on my PIX 501's external interface is opened. But not on 515e with almost similar configuration.
I can telnet FW-EXTERNAL-IP port 80 and 21.
PIX Version 6.3(4)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxx encrypted
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
access-list acl_vpn permit ip
access-list acl_inside permit tcp any eq www
access-list acl_inside permit tcp any eq lotusnotes
access-list acl_inside permit icmp any
access-list acl_inside permit tcp any eq ssh
access-list acl_inside permit tcp any eq domain
access-list acl_inside permit udp any eq domain
access-list acl_inside permit tcp any eq 1863
access-list acl_inside permit tcp any eq https
access-list acl_outside permit icmp any any
pager lines 24
logging on
logging trap debugging
logging host inside
mtu outside 1500
mtu inside 1500
ip address outside XXX.XXX.XXX.XXX
ip address inside
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 XXX.XXX.XXX.XXX
nat (inside) 0 access-list acl_vpn
nat (inside) 1 0 0
access-group acl_outside in interface outside
access-group acl_inside in interface inside
route outside 1
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-3des esp-md5-hmac
crypto map mymap 1 ipsec-isakmp
crypto map mymap 1 match address acl_vpn
crypto map mymap 1 set peer XXX.XXX.XXX.XXX
crypto map mymap 1 set transform-set myset
crypto map mymap interface outside
isakmp enable outside
isakmp key ******** address XXX.XXX.XXX.XXX netmask
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 1
isakmp policy 1 lifetime 3600
telnet inside
telnet timeout 5
ssh outside
ssh outside
ssh inside
ssh timeout 60
console timeout 0
dhcpd address inside
dhcpd dns
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd enable inside
terminal width 80
: end
Please assist
Re: Firewall port 80 opened on external interface issue
You cannot telnet to outside interface of PIX you can use only SSH
command ssh outside permits traffic to outside so you can connect with SSH client if you dont have SSH try putty from following link
You need enable access to outside interface
http outside
This command allows to all outside IP access to PIX via PDM (after authentication with username/password)
If you want specify access only to specific host (IP x.x.x.x)
You can do it in this way:
http x.x.x.x outside
Hope that helps rate if it does
Community Member
Hi M.sir,
Thanks for your quick reply, unfortunately you misunderstood my question/issue.
My firewall's public IP address on the outside interface has port 80 opened. I can run the following command to see that port 80 is opened.
telnet 80
My ethereal result also shows a successful TCP connection handshake. The problem is that I cannot seem to find where is the configuration that opens the firewall port 80 on outside interface.
I have already tried following command
pixfirewall(config)#no http server enable
I can SSH to my firewall, its not the issue. Not intending to use PDM from the outside interface also.
All please assist,
