Firewall Services Module and msfx on a hybrid catos - ios 6500
Hi together,
my problem is, that I can never find how to configure a firewall services module on a catos switch in combination with the msfc. For native IOS there are several examples but for CATOS there is only the Layer 2 part mentioned and also that there must be a single secured Vlan Interface connection between msfc and Firewall services module. But I can nowhere find how to configure it.
If I use the "set vlan {vlans} firewall-vlan {mod}"- command the switch is complaining for those vlans already configured on the msfc!
Does anybody have a working Configuration for hybrid Cat6K for both the Switch and the msfc?
Thanks in advance
Horst
  • Other Security Subjects
Re: Firewall Services Module and msfx on a hybrid catos - ios 65
What version of CatOS are you running?
This link should help (if you haven't seen it already)
http://www.cisco.com/en/US/partner/products/hw/switches/ps708/products_installation_and_configuration_guide_chapter09186a0080159cac.html
bryan
I need samples too for CatOS 3DES version 7.6.1.
Can you give us more hints?
Hi bryan,
thanks for your soon answer.
CATOS is 7.6 . The link I already knew.
I already used the CATOS comand "set vlan vlan_list firewall-vlan module".
But the switch doesn´t do this for vlans already created on the MSFC.
Then I read somewhere that there is 1 SVI (secure vlan Interface)-Connection between MSFC and FWSM possible but nowhere I can see how to create/configure this connection.
All Examples show how to do it with native IOS-Switches and there is just to create a "interface vlan x" but this I already have on the msfc and this is just what the CATOS is complaining about.
Any hints?
regards
Horst
p.s.
The catalyst is a production system, so I have no chance to play on it for hours. Therefor I need someone who maybe already confihured what I want to.
For all who may experience this problem.
Teh solution is to first schutdown the vlan-interface in the msfc then go to catos an type "set vlan vlan_list firewall-vlan module".
After that you can switch to the msfc an "no shut" the vlan-Interface and it will work.
As for all problems I asked in this forum I had to solve it by myself just waiting for the first useful answer....
regards Horst
151
