05-30-2003 09:22 AM - edited 03-09-2019 03:29 AM
I searched the forums, but couldn't find an answer. I'm also new here.
I need to configure a PIX 506 to allow the same port on two different external IP addresses to be forwarded to a port on ONE internal IP address.
EG:
209.123.234.4:8443 -> 192.168.1.50:8443
AND
209.123.234.5:8443 -> 192.168.1.50:8443
Is this possible, and if so, how would I do it?
Thanks!
05-30-2003 09:56 AM
Sould be able to do this for any source coming on port 8443 to the inside destination using port redirection;
More info on below url;
thanks,
yatin
05-30-2003 10:03 AM
Even though I'm logged in, when I click on the link in your reply, I get:
Authentication Required/Forgotten Password
Message #401: Authorization Required/Forgotten Password
I am a logged-in user. How do I access that page?
Thanks!
05-30-2003 10:24 AM
Thanks. I will try this tonight, after hours.
However, I thought this wouldn't work based on another post I read in this forum titled "PIX-515: multiple PAT to the same inside host". Daniel Ruch says he tried basically what you suggest, but that it didn't work.
If I correctly copied the link, you can find it here:
Thanks for any more help you can offer!
05-30-2003 11:05 AM
Actually this will not work. Here is why:
You are translating 2 different ips and same ports to the same ip/ports. And this will confuse the pix which translation object needs to be used when the server send the syn-ack reply. I doubt if pix will even build two translation objects for connection objects to use.
Sorry ! This will not work, and no work around on the pix . Thanks,
Mynul
05-30-2003 11:19 AM
I was afraid of that.
Is it possible to use 2 different external ips with different ports to one internal ip/port? eg:
209.1.1.4:2222 -> 192.168.1.50:4444
AND
209.1.1.5:3333 -> 192.168.1.50:4444
Or, would that still have the same problem?
Thanks so much!
05-30-2003 12:14 PM
Unfortunately, it will.. So long as actual ip/port are the same, it will create problem, doesn't matter what combination of your outside ip/port are.
Mynul
05-30-2003 01:49 PM
The Pix does not handle mapping multiple outside IP/Ports to the same inside host in any manner. Perhaps if you described the goal or problem you're trying to solve, we could offer other alternatives.
05-30-2003 02:16 PM
As weird as this sounds, I need a single server to be accessible from 2 different internet IP addresses.
We have a client program running in an internet appliance on a broadband connection. I need the client to be able to failover whenever it has trouble accessing the server by trying to use a different IP address. However, that different IP address actually needs to be the same server, but by trying to reach it via a different IP address, it can utilize the routing table to make it go out a different interface (like PPP).
I thought that perhaps I could make my cisco give my internal server 2 external IPs, but that doesn't seem feasible.
I keep thinking a Proxy or some other kind of server might be the solution, but I haven't found that by searching the web and don't know how to do it myself.
ANY solutions you have for this would be greatly appreciated!
Thanks!
05-31-2003 12:22 PM
I should've been more specific in that you cannot accomplish that in any manner on the same interface.
Are both IPs that you're trying to NAT for delivered by the same ISP and router? Without router and/or ISP redundancy, having two IPs for the same inside host on a single Pix doesn't accomplish much.
If you have two different ISPs on the same router, you can use the router to NAT on the inbound session to make this work using a single interface and static statement on the Pix. If you have two routers and two ISPs, you can use the routers to NAT the source and destination IPs on inbound to make this work.
05-31-2003 12:03 PM
Hi All,
Well, I should have been a little careful on my earlier post of the url, I thought that the required info was included on that doc.
Anyway, the NAT/PAT many to one from the ouside can be done. The factor that needs to be borne in mind is that you will need to use multiple interfaces.
static (inside,outside-1) tcp 209.123.234.4:8443 192.168.1.50:8443
static (inside,outside-2) tcp 209.123.234.5:8443 192.168.1.50:8443
The next version (6.3.2) of the PIX will allow the above through one interface. The main caveats are that sessions must be initiated from outside and they
must be TCP or UDP.
Hope this helps a bit.
Yatin
05-31-2003 12:25 PM
This news won't help our friend in need here as he has a 506 which is fixed-form-factor and doesn't support virtual interfaces. However, it is great news! Is there a listing yet of new features in 6.3.2? Do you know the expected release date?
06-06-2003 10:04 AM
I think your only option might be to point it to a secondary IP Address assigned to the same NIC on the server. It's a bit dirty, but it should work.
-Joshua
07-15-2003 06:20 AM
I would bind two IP's to your server and create two static mappings to those two IP's.
