05-26-2001 12:52 AM - edited 03-08-2019 08:16 PM
Hi folk,
Any idea what the subject above on pix 5.1 does ?
Apparently I'm receiving a huge number of error messages pertaining to it:
fh_insertb: too many fragments(12) in set
If it's a security attack, how can i stop it ?
06-05-2001 07:06 AM
Which exact version of PIX are you running (5.1(x))? There was a bug in early 5.1 code you might be running into. If youre on 5.1(4) and you are still getting a lot of frags, the PIX is doing its job by blocking them. If you need to know about them, put a sniffer/analyzer on that wire and look at the fragments to learn whats going on.
11-16-2001 12:52 PM
I am getting this same error, but only when I transmit packet from a UNIX enviornment to an NY enviorment. I am running 5.1(4). Any help would be appreciated.
11-27-2001 03:50 AM
Some Unix (Linux e.g.) transmit IP fragments in revers order. Fragmented Linux packets will not pass through the Pix with sysopt security fragguard enabled.
