01-31-2006 04:52 AM - edited 03-09-2019 01:47 PM
We use a 3rd party application that sends and receives files to and from an FTP server for a transcription service. After putting our ASA5510 firewall in place it no longer would allow receiving of files to our internal network. I had to disable the INSPECT FTP feature. That fixed the problem with the 3rd party application but now I cannot receive files using an off the self GUI FTP program. How can I get both programs to work? Thanks!!!
Solved! Go to Solution.
01-31-2006 07:34 AM
Because I only can guess of your ASA configuration, the solution which should work is to setup your GUI FTP to use PASSIVE ftp connection mode.
01-31-2006 07:34 AM
02-07-2006 09:55 AM
I have a similar issue since installation of a 5540 ASA fw. How did you disable the INSPECT FTP feature?. Were you able to do this using the ASDM or cli.
Ian.
