FW options for Cisco IOS
Hi!
Our company planning to delploy a corporate network with Cisco 3660 and PIX 515 in center. What we can lose, if order Cisco IOS for 3660 without FW options? I hear "standart" IP IOS already have some facilities for filtering? What addition features (over IP only IOS ) provide FW IOS options.
  • Other Security Subjects
Re: FW options for Cisco IOS
FW IOS is completely different that the standard IP IOS security features. With a state-full FW you can setup your router to accept only traffic from the Internet if the session has been initiated from the inside network. The router keeps track of a session and only valid traffic will be passed on. The router not only looks at the layer 3/4 information, but it will also use layer 7 information if required (FTP, H323,Realaudio, etc. I haven't even mentioned the (limited) Intrusion Detection System included in the software.
To be short, the Cisco IOS FW goes far beyond the traditionally ACL and is stronly recommended to use as a minimum level of network security (pix would be better).
Thanks. But if we take also an pix, IP only IOS is enough to protect Cisco router themselves?
The PIX will protect anything behind it. So if your router is outside, the PIX can’t protect it. Basic IP is fine even in this application though. For greater security on the outside router, don’t allow telnet access to the serial interface and number your DMZ (between the PIX and the router) 10-dot addresses (rfc1918). Of course you’ll have to put static routes in the router pointing back at the PIX for the NAT’d networks.
I plan to purchase PIX 515 unrestricted and place DMZ on the third ethernet line in PIX.
I wouldn't worry about security with the PIX behind the 3660 I would jsut built a Access list to keep people out of the router block Telnet and maybe ICMP
200
